egnlsn
Sep 20, 2026Aspirant
GS305E and VLANs
I'm trying to get a GS305E switch configured for VLANs. The VLANs at the port on the router to which this switch is connected are 5 (main one) and 7. I need to configure this switch so that VLAN 7 ...
Sep 21, 2026Guru - Experienced User
schumaku wrote:Clearly, the Web UI resp. the IP stack can't be reached over a fully all-tagged trunks as you claimed before. Sorry.
Well, it does work for me - I have no problem reaching the GS108Ev3 with the trunk fully tagged.
schumaku
Sep 22, 2026Guru - Experienced User
StephenB wrote:I have no problem reaching the GS108Ev3 with the trunk fully tagged.
Wonder how ... considering the GS108Ev3, GS308E (and the very similar GS105E, GS305E) don't have any VLAN support on the very basic IP stack.
Beyond, none of the mentioned switches can be discovered by the NETGEAR Discovery tool here, not even in a flat network. Only the Plus Utility can. The Web UI is reachable on the very same IP subnet.
- StephenBSep 22, 2026Guru - Experienced User
No way of knowing exactly how it works, but it does.
I am of course using the same subnet to reach it.
I just checked - the discovery tool finds the GS728TPv2 and the GS510TP, but not the GS108Ev3. This is using a PC connected to my Orbi wifi - I'll double-check ethernet later today, and post back if the results differ.
EDIT- I get the same discovery results when the PC is connected via ethernet. Note it is not directly connected to the "missing" GS108Ev3 switch. Not a problem for me, as the all three switches have reserved IP addresses.
