Naga1337
Jun 29, 2022Follower
GS305E Between Modem and Routers?
Hello all. I am attempting to connect two routers (a tp-link AC1750 and a Ring Alarm Pro base station) to a modem with a single ethernet port on it (a Spectrum E31T2V1). After doing some research t...
Jun 29, 2022Guru - Experienced User
it won't work. reason why is that the majority of ISP's only assign 1 public ip address. The modem takes that address and feeds to the router which assigns private ip addresses. If there's a switch in the middle, your still only getting 1 ip address and its either assigning it to the router or the base station.
so you need to go modem---->router---->base station.
the base station isn't a router as far as I could find unless you have a different version than what I found for it.
