jackheiff
Dec 12, 2020Follower
GS305E How do I share my ethernet service with a second computer?
Current internet service from Spectrum using Cisco DPC3008 cable moden ethernet output to Google Mesh Net router. Etherneet cable from router to iMac. Works fine. Trying to add a second iMac to in...
schumaku
Dec 12, 2020Guru - Experienced User
You can not share the Ethernet based Internet/WAN side. Any wired device must be connected to the router LAN port, if you need more than one this is the port to connect the switch.
FMI:
https://support.google.com/googlenest/answer/6274262
https://support.google.com/googlenest/answer/7215624
Nothing to configure on the switch, not a Netgear issue.
