jcahow
Apr 27, 2023Initiate
GS305EP not connecting
Picked up a used GS305EP switch off eBay and it does not seem to be working correctly.
It does power up (green power LED) and it will power an IP camera on ports 1-4 (green right LED).
It does NOT show any activity LEDS active on any ports when connected to another switch, computer or camera and is not located with the Netgear switch discovery tool.
I tried resetting the switch multiple times and sometimes the port 3 Left LED comes on Orange (no other LEDS light) which goes away after resetting the power.
Since it is not connecting to anything I cannot access the internal web page or use any of the POE powered cameras.
Any ideas how to fix this or is it toast?
- NerdBitAspirant
Just a thought maybe?
You stated it does send power to the camera.
Do the power and activity leds both light up to that specific port?
If yes, maybe connect an ethernet cable to the same port and to your laptop/pc and give the ethernet adaptor a manual IP within the same network of what would be the switch's default IP address. Possibly a tiny label on the underside of the switch.
Then open a browser, and try to access the switch with that IP.
Let me know, how you get on.
Cheers
Kanwal
- ReneDNETGEAR Moderator
Hello jcahow,
And welcome to the NETGEAR Community! 🙂
You can try updating your firmware and resetting the device to factory default and see if the switch will function properly. If not, then the switch may potentially be faulty and needs a replacement. However, we only replace products that are purchased from our authorized reseller, and purchased brand new.
https://www.netgear.com/support/product/gs305ep#download
Have a lovely day,
Rene D
Netgear Team
