RAEC617
Nov 07, 2022Aspirant
GS308E WEB ACCESS
Bought the GE308E and had it since July 22, I got a email to check the product but when I went to 192.168.0.239 or 192.168.4.131 nothing came up both pages timed out? not sure how to get to the switc...
RAEC617
Nov 10, 2022Aspirant
Thank you for the reply, no firmware update. I did check the manual and it said got to 192.168.0.239 I did but my system keeps timing out, now I did get on when I first this to set up a login and password. But now my system keep telling me times out , I restarted and I reset the switch. I just want to get to the page with the switch is but can't seem to get there. I did no changing to the PC or the network I have I have it into a eero Pro6 for the extra ports b/c the pro6 only has 2 ports and I prefer wired over wireless.
Thank you
michaelkenward
Nov 10, 2022Guru - Experienced User
Have you posted you query in the appropriate section?
I can't see it.
The router owners who hang out here won't be able to help.
Switches - NETGEAR Communities
- schumakuNov 11, 2022Guru - Experienced User
No, but created duplicate post instead. Already answered https://community.netgear.com/t5/Plus-and-Smart-Switches-Forum/GS308E-smart-managed-plus-switch/m-p/2270989/highlight/true#M21709
