yosida95
Aug 21, 2026Guide
GS308EP sends management traffic outside configured Management VLAN
Hello, I would like to report a possible VLAN isolation issue with my GS308EP. Environment Device: NETGEAR GS308EP Firmware: V2.0.0.11 (latest as of writing) Configuration: The uplink port ...
Aug 21, 2026Guru - Experienced User
yosida95 wrote:ARP, NTP, DNS, UPnP/SSDP, and other management-plane traffic
Just want to point out that ARP, DNS, and UPnP/SSDP are control-plane, and not management-plane.
That said, if 192.168.8.18 is only part of VLAN 8, then ARP "who-has" packets should only be broadcast to the devices in that VLAN.
- yosida95Aug 21, 2026Guide
Thanks for the clarification.
Yes, 192.168.8.18 is the IP address assigned to the switch and is configured only for VLAN 8.
I observed that the switch sends ARP requests with 192.168.8.18 as the sender across configured VLANs, for example:
17:34:17.716727 28:94:01:XX:XX:XX > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 64: vlan 1, p 0, ethertype ARP (0x0806), Request who-has 192.168.8.1 tell 192.168.8.18, length 46 17:34:17.717436 28:94:01:XX:XX:XX > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 64: vlan 8, p 0, ethertype ARP (0x0806), Request who-has 192.168.8.1 tell 192.168.8.18, length 46 17:34:17.717470 b4:96:91:XX:XX:XX > 28:94:01:XX:XX:XX, ethertype 802.1Q (0x8100), length 46: vlan 8, p 0, ethertype ARP (0x0806), Reply 192.168.8.1 is-at b4:96:91:XX:XX:XX, length 28 17:34:17.718168 28:94:01:XX:XX:XX > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 64: vlan 9, p 0, ethertype ARP (0x0806), Request who-has 192.168.8.1 tell 192.168.8.18, length 46 17:34:17.718937 28:94:01:XX:XX:XX > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 64: vlan 16, p 0, ethertype ARP (0x0806), Request who-has 192.168.8.1 tell 192.168.8.18, length 46I believe these ARP requests should only be present on VLAN 8.
I also observe other traffic generated by the switch itself, such as DNS, NTP, and SSDP, being transmitted with VLAN tags other than VLAN 8.
17:37:49.884570 28:94:01:XX:XX:XX > b4:96:91:XX:XX:XX, ethertype 802.1Q (0x8100), length 94: vlan 19, p 0, ethertype IPv4 (0x0800), 192.168.8.18.123 > 192.168.10.123.123: NTPv4, Client, length 48 17:37:55.889576 28:94:01:XX:XX:XX > b4:96:91:XX:XX:XX, ethertype 802.1Q (0x8100), length 94: vlan 25, p 0, ethertype IPv4 (0x0800), 192.168.8.18.123 > 192.168.10.123.123: NTPv4, Client, length 48 17:38:00.893427 28:94:01:XX:XX:XX > b4:96:91:XX:XX:XX, ethertype 802.1Q (0x8100), length 94: vlan 19, p 0, ethertype IPv4 (0x0800), 192.168.8.18.123 > 192.168.10.123.123: NTPv4, Client, length 48 17:38:05.897160 28:94:01:XX:XX:XX > b4:96:91:XX:XX:XX, ethertype 802.1Q (0x8100), length 94: vlan 24, p 0, ethertype IPv4 (0x0800), 192.168.8.18.123 > 192.168.10.123.123: NTPv4, Client, length 48 17:38:11.902082 28:94:01:XX:XX:XX > b4:96:91:XX:XX:XX, ethertype 802.1Q (0x8100), length 94: vlan 19, p 0, ethertype IPv4 (0x0800), 192.168.8.18.123 > 192.168.10.123.123: NTPv4, Client, length 48- schumakuAug 21, 2026Guru - Experienced User
Correct.
Corrrect again.
Admit, I was impressed to find the Management VLAN config option poping-up on these recent switch firmware updates. But never had any effective project - had aquired a GS308EP and a GS305EP - and I -think- I have observed the similar issues as you correctly and report in a very professional manner.
I'll try to find some old contacts in NTGR to escalate. Mabye fellow LaurentMa can push this thread to the relevant product managers and QA.
-Kurt
Switzerland
- yosida95Aug 23, 2026Guide
Thank you very much for looking into this and for trying to escalate it.
I really appreciate your help. I would be happy to provide any additional packet captures or configuration details if needed.
- StephenBAug 22, 2026Guru - Experienced User
Are you seeing this behavior on devices that are not on VLAN 8?
- schumakuAug 22, 2026Guru - Experienced User
Check the captured data details, clearly showing frames for VLAN 1 9, 16, 19, 24, and 25.
