LW100
Dec 11, 2024Aspirant
GS308Ev4 - Cant login to it via browser on mac
All, looking for some help, I have a GS308Ev4, which I have connected to a SKY Q router... FW version 1.0.0.8... and using the Network Disc tool, it finds the switch on default IP of 192.168.0.209. ...
ErwinL
Jan 15, 2025NETGEAR Moderator
Hello LW100
And welcome to the NETGEAR Community! 🙂
Is it possible for you to try a Windows based computer just to check if you will be able to access the switch from there? Try also making a static IP on your computer with the same range of the default IP of the device and see if you will be able to access it. Just be reminded that you have to be directly connected to the device.
Have a lovely day,
Erwin
Netgear Team
