matthewood
Jul 09, 2023Follower
GS308P DC Barrel Connector Size
Hi there, Does anyone know the size of the barrel connector on the GS308P Router? I need to add a right angle adapter to the end of the connector, and I’ve tried both 5.5mm x 2.1mm and 5.5mm x 2.5mm ...
schumaku
Jul 10, 2023Guru - Experienced User
Barrel connectors also exist in 6.3 x 4.0 mm, 6.0 x 3.0 mm, and 6.0 x 1.0 mm formats. This should help identifying or roughly measuring what you have in hands. Afraid, I don't own any unmanaged Netgear switch.
Keep in mind the GS308P is an unmanaged PoE switch, not a router.
