bcaruso22
Dec 02, 2022Aspirant
GS310TP power plug size
I'm in need of a replacement power supply for a GS310TP. I have seen several 54V power supplies that could work, but I've seen different sized barrel plugs. So i was hoping someone may be able to pro...
- Dec 15, 2022
So I just received the power supply I ordered from my-adaptor.com and it is working great. Description says it is 6.0mm x 3.0mm, so slightly different then mentioned above. However it fits snug, not tight, with no wiggle.
This is the PS I ordered https://www.my-adaptor.com/332-11001-01-m-76199.html
Hope this helps others since I have seen people on other sites also looking for a PS for this switch.
Marc_V
Dec 02, 2022NETGEAR Employee Retired
Welcome to the Community!
48V/54V DC adapters should have a 6.5 x 3 mm size for it's output plug.
HTH
- bcaruso22Dec 02, 2022Aspirant
Marc_V,
Thank you for the information. I believe I found one that will work. I'll post an update if it does as I have seen a few people looking for power adaptors recently.
- bcaruso22Dec 15, 2022Aspirant
