galavichid
Aug 11, 2024Aspirant
GS316EP Remote restart via Telnet\SSH?
Hi, We have 50 Barco F50 Projectors connected to 4x GS116Ev2 switches in our setup. We have a long time issue with the projectors which are disconnecting after X time with no any pattern or order...
schumaku
Aug 13, 2024Guru - Experienced User
galavichid wrote:
I am thinking to upgrade the old GS116Ev2 to GS316EP, but I would like to know if I can restart this model via Telnet or SSH or even disable\enable ports?
My plan is to automate script via Zabbix once a projector is gone offline, and create a trigger to restart the SW or the Port.
Unfortunately it can't be achieved with GS116Ev2.
Hi Gal,
Nothing of all that what could be used (e.g. Telnet/SSH/CLI or SNMP) is available on the Plus Switches. These are (with a few exceptions) built on unmanged switch cores with a plugged-on uC (with a few exceptions) to implement a very basic Web UI along with some discovery and legacy configuration functions.
Consider Smart Managed or similar switches instead.
-Kurt.
