OrbiPhilip
Jan 28, 2023Luminary
GS324T - Random reboots
I have recently started experiencing random reboots of my GS324T. When I lose connectivity my Nagios box (directly connected to the GS324T) shows it losing connectivity first. The GS324T logs (memo...
schumaku
Jan 29, 2023Guru - Experienced User
Does the Nagios system receive and SNMP traps from the switch? needless to say, the Nagios SNMP trap receiver requires to be enabled and active.
Can you provide a list of the recent SNMP queries the Nagios system registered from querying the GS324T switch?
OrbiPhilip
Jan 29, 2023Luminary
SNMP is not enabled. Nagios is polling the system via ping. I have enabled syslog, and the GS sends trap logs to syslog. It's too large to post here, and the forum won't allow text uploads, so here is a google doc link:
https://drive.google.com/file/d/1Ymi8DdKHMQtzNTs4ya8oc4RVxD4FDIG1/view?usp=sharing
Is there an alternate way to reach warranty support? Their emails are no-reply, and when I try to update the ticket on MyNetgear it says "Cannot add case comment. You may not have permission or the case does not exist". I tried to open a new case referencing the old and it says "Something went wrong". It's tough to send the info they have requested when the communication paths are all one way.
- schumakuJan 29, 2023Guru - Experienced User
No idea on how you have tried to contact Netgear customer service or file a hardware warranty case initially, or how you tried to keep the case open.
https://my.netgear.com/home.aspx
-> select your device
-> [Request Hardware Support]
Describe your issue
attach a file (like logs, like the text file you shared to the community)
- OrbiPhilipJan 29, 2023Luminary
That is what I did. It must have been a temporary problem as it is now taking updates again.
I think my next step is a factory reset and reload from backup.
