TCTC's avatar
TCTC
GS324T - Seems that 10/100 devices will not connect properly
Hello, I just purchased a used GS324T switch.  I have Port 1 plugged in to a Nighthawk wireless router.  The wireless router is connected to a cable modem.  All wireless clients on the Nighthawk wor...
  • DaneA's avatar
    Mar 29, 2020
    TCTC
    Welcome to the community! :)
    Activate again the latest firmware v1.0.0.27 on the GS324T then perform a factory reset.  Check if the same problem occurs.
    DaneA
    NETGEAR Community Team
ProSupport for Business
