sparky2020
Nov 07, 2017Aspirant
gs510tpp ports losing connection to network
I have a strange problem. Had a bunch of RUKUS R510 ap's connected to the poe switch for over 5 weeks on a bench, all working fine, devices connecting to the ap's and network with internet access. Th...
- Nov 08, 2017
Hi Mate
Thanks for your advice. You are right , I could change the setting in CST port configuration to disable the settings. But would not fix the real problem on the network with the flooding of the BPDU packets. I checked the switches. all flashing like mad. Started foot patrol on the network to all the office and asking questions. A bright staff member found a cable and decided to plug it into the network and created a loopback between two points.
This slowed down the whole network, internet access on the network was at snails pace and put the 3 Netgear POE switches on the uplink ports to D-Disable.
So everyone could connect to the Ap's but no traffic to anywhere.. I just had all the new cables fitted to 26 rooms for the Rukus AP's back to new patch panels, then put the POE switches in and everything was sweet and fine for 2 days. Well, until yesterday afternoon.
I have it all sorted now and all the switches and AP's back up and running.
I could disable the settings as you suggested, but I think I will leave it. It will tell me if anyone else has created a loopback, not that I want it.
Thank you very much for your advice, It was very helpful and pointed me in the right direction. You Are a star.. and well appreciated.
sparky2020
Nov 08, 2017Aspirant
Done a firmware update to ver 6.6.2.8. still same problem. The ports on the POE switch are supposed to autonegotiate and should sense that whether they are connected to a poe device or another network switch. I have removed the switch from the network and is on a bench just connected to a laptop and no other devices. as soon as i connect it to the networkthe port goes down d-disabled.
Hopchen
Nov 08, 2017Prodigy
Hi sparky2020,
This is not a bug :)
So, it is not a question of whether "firmware X" has a solution (we will of course always recommend to use the latest firmware). Did you do as suggested in my previous post? It is not PoE related as I initially thought it might have been. It is STP related.
