adamw-ms
Jul 29, 2022Aspirant
GS724T fans
Could somebody confirm whether all 4 versions (v1, v2, v3, v4) have mechanical 40 mm fans on board? Thorough documentation is hard to find, especially for the older models. I would rather avoid...
schumaku
Jul 29, 2022Guru - Experienced User
most likely, the switch fans are electrical powered.
- adamw-msJul 29, 2022Aspirant
Let me rephrase my questions:
1. Does GS724T v1 have spinning mechanical fan(s)?
2. Does GS724T v2 have spinning mechanical fan(s)?
3. Does GS724T v3 have spinning mechanical fan(s)?
4. Does GS724T v4 have spinning mechanical fan(s)?- schumakuJul 29, 2022Guru - Experienced User
Sorry, not a much better question - yes, the air is moved mechanically of course. But this is just the beginning.
Almost all of these switches use axial fans. Specs vary between each hardware version. Nominal diameter, mounting hole distance, thickness, then voltage, nominal RPM, RPM regulation like voltage or PWM for example), airflow at nominal RPM, tach signal, ...
You are advised to check what is installed on your hardware. Search for the same or very similar equivalent with matching specs.
Netgear does not offer replacement fans. You need to work with the popular sources like eBay, Amazon, ... where various vendors have offerings up. Still, the information might be wrong, so watch your step.
Last advise: A silent fan not never provide the correct cooling. Never. Even if we have some freaks around here and on other communities pushing fan makes like ebm-papst or Noctua. best stuff you can find for e little bit more $$$. Yes, these make excellent fans, Noctua makes extremely silent fans, top notch quality. The noise however depends on the fan tip speed - and so does the airflow, as well as the pressure the fan can generate. Be warned: You can easy end with silent fan. If the hardware monitoring does expect an RPM in the range of 8k...16k RPM there can be still errors shown in the hardware monitor. it's as essential to have the right engine, the matching propeller and the required take-off RPM and thrust. Otherwise your aircraft won't perform, won't come off the ground before the runway end, will poorly climb or not reach the expected horizontal speed.
