Mr_Robot
Jan 28, 2016Aspirant
GS724T or GS716T trunking question
I have a build based on HP ProCurve switches. #2 switch has set VLANs as #1 both of them have own internet feeds and are #1 is trunked with #2 in case one of those internet feeds will fail or switche...
- Feb 03, 2016
I think I have found what I was seraching for on those two sites:
https://community.spiceworks.com/topic/248311-netgear-switches-vlans-and-trunking
JennC
Jan 29, 2016NETGEAR Employee Retired
Hello Mr_Robot,
Welcome to the community!
We may need more information of the setup you currently have on these switches. Can you post a simple network diagram that shows the VLANs too and other info that may help?
- Mr_RobotFeb 02, 2016Aspirant
HP switches (both) configuration looks like
where on red are marked ports which connect both switches (SW01 and SW02) between. Stack port 1/0/22 is not a real "stackable" as both switches works on their own - just a port with a connection between to "feed" SW02 with the WAN from SW01 porst 1/0/23 or 1/0/24
- Mr_RobotFeb 03, 2016Aspirant
- JohnRoFeb 03, 2016NETGEAR Employee Retired
Hello Mr_Robot,
We're glad to know that the KB articles helped you achieved the setup you needed. If you have more questions please feel free to post a new topic. You can also mark the post as a solution, this will help other users if they encounter the same issue.
Thanks,
