Fulman
Mar 27, 2018Aspirant
GS724T smart switch version?
Hello, I have just got a 2nd hand GS724T smart switch and want to check that the firmware version is the latest one, however i can't find the version number of the switch anywhere on the unit or ...
- Mar 28, 2018
Dear Ian,
Not fluent with a potentially older factory designation scheme I'm afraid.
According to the firmware version, it looks like a GS724Tv1 -> https://www.netgear.com/support/product/GS724Tv1.aspx#Firmware%20Version%201.2.3?cid=amb - and it has some updates pending.
schumaku
Mar 28, 2018Guru - Experienced User
Dear Ian,
Fulman
Mar 28, 2018Aspirant
Hi Schumaku,
That worked perfectly thank you. It's now on the latest firmware version.
regards
Fulman
