dbarlow2
Dec 31, 2023Tutor
GS724T v2 dead power adaptor
Hi, the power adaptor, Model ADP-40VP from Delta Electronics is dead. Apparently this adaptor is obsolete. There was an alternative made by Artesyn Model NLP40-7605J but this is now unavailable. ...
Jan 05, 2024Guru - Experienced User
I presume we are looking at the internal power supply for these units?
- dbarlow2Jan 05, 2024Tutor
It's the internal power supply that has died, Delta Electronics ADP-40VP.
I'd like to remove the dead internal PSU and hook up a 5V 40A laptop type external PSU. They only cost around $20 which would be cheaper than repairing the ADP-40VP. I understand the capacitors tend to go on these. I'm not proficient enough to replace burned out capacitors.
- FURRYe38Jan 06, 2024Guru - Experienced User
Laptop power adapters are a bit different in regards to end poing plug and two contact connection which may differ from the internal power adapter and wiring seen there. Also may differ in amps as well.
Do the tops of the caps look popped or bulging any on the internal power supply?
Any looked burnt?
Do a search online to see if there are any internal power supplys available with similar power specs as internal if you haven't already.
- plemansJan 08, 2024Guru - Experienced User
I was playing on ebay and found a couple power adapters but their price was asinine. I'd probably just see what you can setup to work. You're biggest challenge is going to be figuring out what all the outputs are from the supply. I see 6x wires output with 2x different colors. If they're just running power to the same color with same voltage or if it changes. tough to know. without one to measure
