PFACB
Mar 13, 2026Aspirant
GS724TPv2 Auto-VoIP Firmware Version
I have a number of GS724TPv2's and want to start using the Auto-VoIP features. I can get them to firmware version 1.1.50.39 without issue, but read that if I want to go to the latest (6.2.1.13) it w...
- Mar 13, 2026
Mixing up different switch models? There is no v6.x.x x firmware for the GS724TPPv2. The major update step requiring erasing the config os the conversion from some v1.x via an intermediate version to v2.x. Follow the conversion stepsas documented carefully
So yes, you have to take full notes of the complete existing v1.x config, and re-do it from scratch on V2 x.
As if writing, the current version is -> https://kb.netgear.com/000066697/GS724TPv2-GS724TPP-Firmware-Version-2-0-8-21
V6.x only exists for the newer GS724TPv3 / GS724TPPv3 models.
schumaku
Mar 13, 2026Guru - Experienced User
PFACB
Mar 17, 2026Aspirant
Great, thanks. For some reason I thought you could go to 6.x.x.x on GS724tpv2, but see now that 2.0.8.21 is the latest version I can get to right now.
