Zbynek
Jan 14, 2026Aspirant
GS724TPv3 The switch loses IP connection about 1 time in 5 days.
Hi, I have Netgear switch GS724TPv3, newest firmware installed The switch loses IP connection about 1 x every 5 days. I don't know why? While power supply of IP cameras powered via POE is...
Jan 14, 2026Guru - Experienced User
Zbynek wrote:The switch loses IP connection about 1 x every 5 days.
I don't know why?
I am thinking a failing switch port is one possibility.
Another thing you might try is a hardware reset of the switch. I had what looked like a failed switch port on my one GS724 (different version) years ago, and a hardware reset cured it.
- ZbynekJan 15, 2026Aspirant
I have tried hard reset and factory reset multiple times.
The Switch is incredibly slow and the connection is unstable.
I will have to try the hard reset again today without any devices connected.
