Zbynek
Jan 14, 2026Aspirant
GS724TPv3 The switch loses IP connection about 1 time in 5 days.
Hi, I have Netgear switch GS724TPv3, newest firmware installed The switch loses IP connection about 1 x every 5 days. I don't know why? While power supply of IP cameras powered via POE is...
Jan 14, 2026Guru - Experienced User
Zbynek wrote:While power supply of IP cameras powered via POE is maintained.
IP connectivity from router and connected devices to switch is lost.
Have you tried using a different switch port (and also a different LAN port on the router)?
Zbynek wrote:Looking for a solution to the problem of setting up a reboot script for switch GS724TPv3 from my NAS Synology via ssh or telnet.
Can you reach the switch's web page from a connected device when the problem occurs?
Zbynek
Jan 15, 2026Aspirant
Thanks for the advice.
I'll try a different port on the router and switch.
Unfortunately I can't access the switch's web. §
The switch is also inaccessible in Netgear Insight.
I was thinking about rebooting as a preventative measure,
like rebooting every 3 days at night to avoid a drop in connection.
- schumakuJan 15, 2026Guru - Experienced User
The switch is also inaccessible in Netgear Insight.All application layer, no matter if it's the Web UI, Insight portal or App - it requires an active, working and mostly healthy connection path.
Zbynek wrote:
The Switch is incredibly slow and the connection is unstable.
Cabling, hardware, Spanning Tree issues .... collecting syslog output now, for example on your NAS syslog service, to stop digging in the dark?
