Zbynek
Jan 14, 2026Aspirant
GS724TPv3 The switch loses IP connection about 1 time in 5 days.
Hi, I have Netgear switch GS724TPv3, newest firmware installed The switch loses IP connection about 1 x every 5 days. I don't know why? While power supply of IP cameras powered via POE is...
Zbynek
Jan 15, 2026Aspirant
Thanks for the advice.
I'll try a different port on the router and switch.
Unfortunately I can't access the switch's web. §
The switch is also inaccessible in Netgear Insight.
I was thinking about rebooting as a preventative measure,
like rebooting every 3 days at night to avoid a drop in connection.
schumaku
Jan 15, 2026Guru - Experienced User
Zbynek wrote:Unfortunately I can't access the switch's web.
All application layer, no matter if it's the Web UI, Insight portal or App - it requires an active, working and mostly healthy connection path.
Zbynek wrote:The Switch is incredibly slow and the connection is unstable.
Cabling, hardware, Spanning Tree issues .... collecting syslog output now, for example on your NAS syslog service, to stop digging in the dark?
