fcos
Nov 10, 2017Aspirant
GS724Tv4 and SFP
Dear Sirs,
I would like to buy two GS724Tv4 switches and connect each other by the SPF. Which SPF module is available for this switch models?
Another, related, question: are any SPF module availa...
LaurentMa
Nov 13, 2017NETGEAR Expert
Hi,
AGM734 copper module will also work with GS724Tv4 so that you can "convert" one or two dedicated SFP ports to 1000BASE-T RJ-45. Beware, no auto-neg will be supported, and no half-duplex allowed. Link will only be established if 1000Mbps with full-duplex operation.
fcos
Nov 17, 2017Aspirant
Thanks Laurent,
I was not sure about the compatibility between the switch and the SPF AGM734 copper module.
