Joe9090
Oct 29, 2017Aspirant
GS728TP VLAN Routing What I am Missing
Hi, I've got a couple of VLAN's setup as a test but I am struggling to get routing between them working and I must be missing something simple. The setup is like this: ...
- Nov 06, 2017
It turns out it was the Windows firewall blocking the pings! Doh.
Thanks for the help.
DaneA
Oct 31, 2017NETGEAR Employee Retired
Hi Joe9090,
Welcome to the community! :)
Let me share the article below and use it as your reference guide:
VLAN Routing on NETGEAR Smart Switches
DaneA
NETGEAR Community Team
- Joe9090Oct 31, 2017Aspirant
Thanks for the info but that was the guide I used to do my setup from.
I double checked everything was correct on my Switch but I still couldn't ping a device on the other VLAN.
- DaneANov 01, 2017NETGEAR Employee Retired
Kindly try to reboot the GS728TP switch and see if it helps.
DaneA
- Joe9090Nov 06, 2017Aspirant
- DaneANov 07, 2017NETGEAR Employee Retired
Thanks for the update and you're welcome. I'm glad to know that you were able to figure out what is causing the problem. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
