SRE
Jul 26, 2016Aspirant
GS728TS Stack issues with interfaces and LAG's
Hi, We have 2 x GS728TS switches (running firmware 5.3.0.26) connected together in a stack with dual stacking cables. There are 4 servers connected to the stack via LAG's. Each LAG consists o...
- Aug 17, 2016
Hi,
During an extensive maintenance window last night, I powered down and removed all power to both switches in the stack for around 5 minutes.
I then re-applied power to both switches and after allowing then to boot up, checked them and they now appear to be working correctly again.
I have just re-checked the switches (approx 8 hours later) and they are still working fine - no issues noticed or detected.
Regards
Shaun
DaneA
Jul 31, 2016NETGEAR Employee Retired
Hi SRE,
Just want to follow-up on this. Were you able to do a packet capture using Wireshark?
DaneA
NETGEAR Community Team
