SRE
Jul 26, 2016Aspirant
GS728TS Stack issues with interfaces and LAG's
Hi, We have 2 x GS728TS switches (running firmware 5.3.0.26) connected together in a stack with dual stacking cables. There are 4 servers connected to the stack via LAG's. Each LAG consists o...
- Aug 17, 2016
Hi,
During an extensive maintenance window last night, I powered down and removed all power to both switches in the stack for around 5 minutes.
I then re-applied power to both switches and after allowing then to boot up, checked them and they now appear to be working correctly again.
I have just re-checked the switches (approx 8 hours later) and they are still working fine - no issues noticed or detected.
Regards
Shaun
JohnRo
Aug 12, 2016NETGEAR Employee Retired
Hi SRE,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
SRE
Aug 17, 2016Aspirant
Hi,
Regards
Shaun
- DaneAAug 18, 2016NETGEAR Employee Retired
Hi SRE,
I appreciate the update you have posted. I am glad that your switches are now working fine. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
NETGEAR Community Team
