luas
Dec 13, 2018Tutor
GS748T Issue with DHCP filtering
Hi,
I have an issue with a freshly configured GS748Tv4, where DHCP filtering is not working as expected.
I enabled DHCP filtering and set port 50 as trusted, all other ports as untrusted. But whe...
- Dec 16, 2018
Hi luas,
Let us isolate the problem. Kindly answer the questions below:
a. Was DHCP Filtering on the GS748Tv4 switch working before?
b. Is the DHCP server connected directly to port 50 (uplink port)?
c. How is everything connected? It would be best if you post an image or screenshot of your detailed network setup.
d. Have you tried to reboot the GS748Tv4 switch? If not yet, kindly try it then check if the same problem will occur.
e. Have you just newly updated the firmware of the GS748Tv4 switch to v5.4.2.30? If yes, I suggest you to perform a factory reset then reconfigure the settings from scratch and check if the same problem will occur.
DaneA
NETGEAR Community Team
DaneA
Dec 16, 2018NETGEAR Employee Retired
Hi luas,
DaneA
luas
Dec 17, 2018Tutor
Hi,
thanks for your reply!
Right now, I can't reproduce it. I guess it was some issue with the notebook caching the address.
