moonwatcher64
Nov 15, 2017Luminary
GS748TP Switch How much Power does it consume?
This might sound mad but our electrictiy bill is huge and the only new suspect is the GS748TP switch we installed a while back. Could it be that this is consuming the juice? It certainly sounds l...
- Dec 07, 2017
Hi John and thanks for the follow up. Happy to close off the issue but have a couple of follow ups which I guess is more logical to post separately. Many thanks for your assistance with this one.
JohnC_V
Nov 17, 2017NETGEAR Employee Retired
Hi moonwatcher64,
Welcome to our community!
I believe this GS748TP has a max power budget of 384W. Once the ports are not being used, it will not provide any power. It will automatically shut off because of its auto-sensing feature. It might be better if you could remove it first to your network just to isolate the case.
Here is the datasheet of the GS748TP.
- moonwatcher64Nov 18, 2017Luminary
Hi John and thanks for the feedback.
This is what I 'sort of' rationalised but good to hear it from more skilled people.
And for sure I think it's worth to drop it out of the environment to see how that affects the house electricty consumption.
Just out of interest, if I were to replace the unit with another Netgear 48 port Giga switch (for home use) that had low power consumption what might you suggest? I'm thinking to maybe keep the PoE element separate...on a separate switch. The GS748 is incredibily noisey.
Many thanks
- JohnC_VNov 28, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- moonwatcher64Dec 07, 2017Luminary
