moonwatcher64
Nov 15, 2017Luminary
GS748TP Switch How much Power does it consume?
This might sound mad but our electrictiy bill is huge and the only new suspect is the GS748TP switch we installed a while back. Could it be that this is consuming the juice? It certainly sounds l...
- Dec 07, 2017
Hi John and thanks for the follow up. Happy to close off the issue but have a couple of follow ups which I guess is more logical to post separately. Many thanks for your assistance with this one.
JohnC_V
Nov 28, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
moonwatcher64
Dec 07, 2017Luminary
