UPP_Ronnie
Oct 14, 2019Tutor
GS752TP - Configured static management IP but cannot get to web interface
Hi all,
Today unpacked the switch and read the installation booklet.
Configured my own laptop to have ip 192.168.0.50 and successfully connected to the switch on 192.168.0.239
changed System > Management > IP Configuration to 10.90.50.9 which is the static IP I want this device to have when i plug it into my FortiNet Switch.
But i cannot get to this Dell GS752TP when it is connected to my Fortiswitch and my own laptop is connected to Fortiswitch.
I can only connect if i plug my laptop straight in to the Dell switch.
Am i overlooking something???
All soved, turned out the FortiSwitch blocked the port that connected to the NetGear switch due to some settings that was enabled.
Edge Port and STP. once i turned those off on the FortiSwitch port then we got somewhere :)
1 Reply
