EFaden
Sep 14, 2013Aspirant
GS752TP - Slow Web Interface
Anyone else have this problem? The web interface is so slow as to almost become unusable. It loads the background then just hangs for a good 20 to 30 seconds. Sometimes it loads the buttons... some...
- Jan 29, 2014I've been having this same problem for some time now.
As a "fix" \ "workaround" \ "bodge" I've used Firefox Portable 3.5.6 to update changes to VLAN\LAG settings.
This really isn't ideal, but does work.
/pokes Netgear with a big pointy stick!
Tyson_
Oct 27, 2015Aspirant
I as well am experiencing this. THe web interface is painfully slow. Clicking on anything results in a 5-10 second wait, every time. It's exhausting. Yes, I've tried all the browsers. Yes the problem exists with all of them. With every firmware upgrade I hope that it will be fixed. Alas, still, even with the latest, still slow. I really don't fancy spinning up an XP machine just to manage my router...
spizzy74
Nov 06, 2015Aspirant
I also need to be able to configure LAG but cannot using any browser.
This is a real issue.
Can netgear tell me exactly what browser and version is supported since none of the big 4 browsers arent?
