EFaden
Sep 14, 2013Aspirant
GS752TP - Slow Web Interface
Anyone else have this problem? The web interface is so slow as to almost become unusable. It loads the background then just hangs for a good 20 to 30 seconds. Sometimes it loads the buttons... some...
- Jan 29, 2014I've been having this same problem for some time now.
As a "fix" \ "workaround" \ "bodge" I've used Firefox Portable 3.5.6 to update changes to VLAN\LAG settings.
This really isn't ideal, but does work.
/pokes Netgear with a big pointy stick!
EFaden
Sep 26, 2013Aspirant
Turns out there is some sort of javascript error. It is a modification not allowed error on line in 756 of globalFunctions.js. It gets triggered on several pages, but the first I found was the LAG config page. Netgear support seems to be ignoring me... but maybe they will fix it. Their response was to use IE6 to 9 in windows...
Pretty lame that they can't manage to support any modern browser on a brand new piece of hardware. Most likely will be using the Cisco 200 series in the future.
