EFaden
Sep 14, 2013Aspirant
GS752TP - Slow Web Interface
Anyone else have this problem? The web interface is so slow as to almost become unusable. It loads the background then just hangs for a good 20 to 30 seconds. Sometimes it loads the buttons... some...
- Jan 29, 2014I've been having this same problem for some time now.
As a "fix" \ "workaround" \ "bodge" I've used Firefox Portable 3.5.6 to update changes to VLAN\LAG settings.
This really isn't ideal, but does work.
/pokes Netgear with a big pointy stick!
adit
Sep 26, 2013Mentor
Which browser are you using?
