EFaden
Sep 14, 2013Aspirant
GS752TP - Slow Web Interface
Anyone else have this problem? The web interface is so slow as to almost become unusable. It loads the background then just hangs for a good 20 to 30 seconds. Sometimes it loads the buttons... some...
- Jan 29, 2014I've been having this same problem for some time now.
As a "fix" \ "workaround" \ "bodge" I've used Firefox Portable 3.5.6 to update changes to VLAN\LAG settings.
This really isn't ideal, but does work.
/pokes Netgear with a big pointy stick!
EFaden
Nov 15, 2013Aspirant
mEDIEVIL wrote: Has anyone had any luck in this, any tricks to get around it?
In any page that I want to see ports and select them individually, they are just not there. So LAG is where my main need is but I noticed it in Protected ports as well.
I have tried it in Safari, Chrome and Firefox in MAC OS X. (Firefox seems to work the best but definitely not perfect)
and Windows 7, Firefox, Chrome and IE9. I installed an old XP SP2 this morning to get to IE6 and it just didn't want to play at all.
I had assumed it was DOA and am waiting for a replacement but I am now thinking the next one will be the same.
From what I was able to figure out is that there are JS errors on several browsers which break the page. I was able to get it to work in IE8... but support just brushed me off saying browser "X" wasn't supported.
