EFaden
Sep 14, 2013Aspirant
GS752TP - Slow Web Interface
Anyone else have this problem? The web interface is so slow as to almost become unusable. It loads the background then just hangs for a good 20 to 30 seconds. Sometimes it loads the buttons... some...
- Jan 29, 2014I've been having this same problem for some time now.
As a "fix" \ "workaround" \ "bodge" I've used Firefox Portable 3.5.6 to update changes to VLAN\LAG settings.
This really isn't ideal, but does work.
/pokes Netgear with a big pointy stick!
ebixby
Dec 08, 2013Aspirant
EFaden wrote: I was able to get it to work in IE8...
Thanks for the tip. I was having the exact same problem, and thank goodness I still have a VM sitting around running XP. Serious issue, Netgear, forcing customers to run antiquated browsers to manage their equipment...
