shotokan
Feb 25, 2016Aspirant
GSS108E firmware upgrade timeout - no solution using arp
Hi there, already digged through the community and found some hints but neither worked. After trying to update the firmware from 1.0.0.0 to 1.0.0.1 (after 30% a TFTP timeout occured), the swi...
- Feb 26, 2016
I had the same problem. Finally solved it.
Open a command prompt as administrator.
Run:
netsh interface ipv4 add neighbors "Ethernet" 192.168.0.3 a0-63-91-89-1f-da
Replace "Ethernet" with the name of your windows 10 network connection, 192.168.0.3 with the ipaddress of your GSS108E and a0-63-91-89-1f-da with the MAC-address of your GSS108E.
Hope it helps.
Best regards,
Lage
JohnRo
Feb 25, 2016NETGEAR Employee Retired
Hello shotokan,
Welcome to the community!
Try initiating a factory default by pushing the reset button on the back part of the switch. Try to go through again using the arp command mentioned on the other post. Make sure all firewalls and anti-virus softwares are temporarily disabled on the computer.
Let us know what happens.
Thanks,
SM3NSE
Feb 26, 2016Initiate
Run:
Hope it helps.
Best regards,
Lage
- JohnRoFeb 26, 2016NETGEAR Employee Retired
Hi SM3NSE,
Welcome to the community and thanks for the contribution! I hope shotokan can try your suggestion.
Thanks,
- shotokanFeb 28, 2016Aspirant
Hi all,
thank you for the fast responses. Indeed it was the netsh command that helped. Now the firmware was updated and the switch is responsive again.
Best regards,
shotokan
