thsturm
Nov 06, 2015Aspirant
GSS108E: firmware upgrade timeout
Hi all, I was trying to upgrade the firmare of my GSS108E to version 1.0.0.1. The firmware was load until about 40%, then the "Prosafe Plus Configuraton Utility" reports an timeout. The "PPC...
- Nov 09, 2015
Solution here:
Enjoy.
Summary: Enter a manual arp entry for the IP and MAC address of your GSS108E. Expect Netgear engineers to think you're talking about the GS108E :)
Eaglehawk
Nov 09, 2015Apprentice
Solution here:
Enjoy.
thsturm
Nov 09, 2015Aspirant
Hi Eaglehawk,
thank you for your hint: I finally updated my GSS108E :-)
The "arp -a" did not work on Win10: access denied, even if I started 'cmd.exe' or 'PowerShell' as admin :-(
Your last post (use "interface ipv4 add neighbors ...") did it finally.
Thank you: I learnt something new again!
- JohnRoNov 09, 2015NETGEAR Employee Retired
Hello thsturm and Eaglehawk,
I'm replying to also give a kudos to Eaglehawk. There was an issue with the forwarding rate of the ARP packets on FW 1.0.0.0, this was fixed on FW 1.0.0.1. I am glad you were able to update the firmware of your device!
Thanks,
- EaglehawkNov 11, 2015Apprentice
The kudos should really go to lexav, they posted the actual soution. Thanks anyway :)
