bs98909
Feb 05, 2017Aspirant
GSS116E and GSS108E daisy chaining
Greetings.
This is what I have that works:
FiOS Modem (DHCP) >>> Cisco DS2008 (8port) >>> Apple 3Tb timecapsule ~~~ wifi ~~~ Apple 2TB timecapsule >>> GS116Ev2
What I want is
FiOS Modem (DHCP) >>> Cisco DS2008 (8port) >>> GS108Ev2 >>> Apple 3TB timecapsule
\ >>> GS116Ev2 >>> Apple 2TB timecapsule
What I connect the cable to from the DS2008 to the GS116Ev2 all comms to the GS116 seems to get lost. If I disconnect 200 foot cable that I ran from the DS2008 then after 30 sec or so I have connectivity again.
I do not believe that the GS have uplink ports, and looking at the NetGear prosafe plus config utility that there are any special settings for uplinks or daisy-chaing.
I have also tried starting the GS116 network from a cold boot thinking that the DHCP setting would have to get resync'd
I found that the cable from the 2TB timecapsule was the issue. I removed the cable from the GS116E and the network conflict went away!
The 2TB timecapsule is still on the network, but now just using wifi and not an RJ45.
- bs98909Aspirant
- XavierLLNETGEAR Employee Retired
thanks for sharing bs89909 , looks that the cable was creating a network loop!
Xavier Lleixa
NETGEAR CBU PLM
