tony_ngear
Oct 22, 2016Aspirant
GSS116E Backplate Problem
The small rectangular plate covering the locking tab assembly has come off due to the underlying retaining bush coming free from the backplate. Anyone know how the spring fits in with the other two p...
- Oct 30, 2016
You're welcome!
I'm glad that the replacement unit is working fine. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
DaneA
Oct 26, 2016NETGEAR Employee Retired
Hi tony_ngear,
I have found out that a replacement has been processed for your GSS116E. Hope that the replacement unit would be working fine. :)
DaneA
