smalmaer's avatar
smalmaer
GSS116E: unable to upgrade bootloader after firmware upgrade
Hi,
After Upgrading my GSS116E - ProSAFE 16-port Gigabit Click Switch from Firmware version v1.0.0.0 to  v1.6.0.3 via the Plus Utility
when I call the web gui i'm presented with a page that only shows firmware Update or Reboot as the menu options on the right side.
So I can't continue with the boot loader update. In the web gui it doesn't accept the firmware file again.
In the Plus Utility the device is marked with *. If you try to connect, it immediatly ask for a firmware file.
From the utitlity you can repeat the firmware update to 1.6.0.3, but it doesn't solve the web gui beeing trapped in the frimwar upgrade.
Pressing teh facory default button hasn't helped either.
How can this be solved?
regards alex
PS: The same procedure worked on the GSS108E
  • I could solve the issue myself via a firmware downgrade to 1.0.0.6, then reset to factory defaults and then update the boot loader
    and then upgrade to 1.6.0.3
    alex
1 Reply
    alex
ProSupport for Business
