DonD
Jan 13, 2016Guide
Guest WiFi connection can't access Internet using WN203 access point and GS108E in VLAN config
I'm new to VLAN technology, and am beginning to wish I never heard of it. I'm try to setup a Guest SSID and main network users SSID, such that Guests can't access main network resources. Here's ...
- Jan 13, 2016
Okay, got it! I think I finally understand how VLAN configuration works. The example on that link really helped! I just ordered a Netgear FVS318N. I put one of those in a previous church, and now will put one in my current church.
Thanks again for you help!
Don
JohnRo
Jan 13, 2016NETGEAR Employee Retired
Hello DonD,
Welcome to the community!
For you to achieve the setup you wanted you'll need a router with VLAN capabilities, this will let your control routing and also can give you another set of IP addresses for the guest network. The GS108E does not have DHCP and routing capabilities since it is only a Layer 2 switch.
I hope this information helps, let us know if you have more questions.
Thanks,
DonD
Jan 13, 2016Guide
Thanks, JohnRo for your reply.
Is it necessary for the main network computers and Guest connected computers to have VLAN capabilities also?
Also, could I have chosen a different switch that would solve this problem and still use the same router?
Don
- JohnRoJan 13, 2016NETGEAR Employee Retired
Hi DonD,
Most of the computers these days are already VLAN unaware so there's no need to worry much about the devices connecting. Yes, you have that option as well but Layer 3 switches are a bit expensive (could be more expensive than a VLAN router).
Also, here's an example of creating multiple VLAN configuration that you may use as a guide.
Thanks,
