DonD
Jan 13, 2016Guide
Guest WiFi connection can't access Internet using WN203 access point and GS108E in VLAN config
I'm new to VLAN technology, and am beginning to wish I never heard of it. I'm try to setup a Guest SSID and main network users SSID, such that Guests can't access main network resources. Here's ...
- Jan 13, 2016
Okay, got it! I think I finally understand how VLAN configuration works. The example on that link really helped! I just ordered a Netgear FVS318N. I put one of those in a previous church, and now will put one in my current church.
Thanks again for you help!
Don
JohnRo
Jan 13, 2016NETGEAR Employee Retired
Hello DonD,
They are VLAN unaware so the control will be from the switches. They will just correspond to the network they are connected to.
Thanks,
DonD
Jan 13, 2016Guide
Don
- DaneAJan 14, 2016NETGEAR Employee Retired
Hi DonD,
In addition to the helpful link that JohnRo has shared with you, let me also share this article as reference guide in setting up VLANs on a NETGEAR switch and assigning VLANs on a wireless network configured in a NETGEAR access point.
Hope it helps. :)
DaneA
NETGEAR Community Team
- DonDJan 14, 2016Guide
Thanks, DaneA. This is also helpful.
Don
Hi DonD,
You're welcome! :)
Feel free to post your future concerns here on the community.
Cheers,
DaneA
