Tupo
Nov 14, 2018Aspirant
HDMI Over Ethernet With Netgear GSS108E & VLAN Tagging
I am looking to transmit both the USB and HDMI of my PC to the living room TV. I am aware you can stream the PC image but I wish for a pure signal.
I have the following USB over ethernet extend...
- Nov 14, 2018
Happy to help and I just realized I didn't look up your USB Extender. It turns out this USB kit is NOT IP, it speaks again another (proprietary) language and it's not meant to leverage an Ethernet network. So you're back to:
- The HDBase-T kit that you have selected will use its own, dedicated LAN cable. You must have one independent CAT5e, CAT6 or better LAN cable available between your PC and your TV. In fact, the HDBase-T transmitter (PC side) will send the video from your PC to the HDBase-T receiver (TV side) using a LAN cable in between. This LAN cable cannot go through a switch or anything else, it must be entirely dedicated and straight between the Tx and the Rx.
- The USB kit that you have selected will use its own, dedicated LAN cable. You must have one independent CAT5e, CAT6 or better LAN cable available between your PC and your TV. In fact, the USB transmitter (PC side) will send the USB signals from your PC to the USB receiver (TV side) using a LAN cable in between. This LAN cable cannot go through a switch or anything else, it must be entirely dedicated and straight between the Tx and the Rx. Again.
Net net: you must have two dedicated LAN cables available between your PC and your TV. I originally thought you selected USB-over-IP technology, but you did not.
At this stage, your Ethernet Switch location, usage, and availability don't matter because none of your Audio/Video/USB transport products are Ethernet-based. The title of your post should be understood as HDMI and USB over proprietary extenders because nothing here is actually over-IP.
