chad2324
Nov 26, 2017Aspirant
Help with Mynetgear account
I need to reset my password for my "mynetgear" account, but I no longer have access to the email account I used to register. I can't create a new account because my device is already registered. Ple...
chad2324
Nov 28, 2017Aspirant
I can't as I mentioned in the post, I don't have access to the email account used when I registered.
DaneA
Nov 28, 2017NETGEAR Employee Retired
It seems that you will need to retrieve first the e-mail address you have used when you created your MyNETGEAR account. If ever you have used a Gmail account or Yahoomail account, then there are ways to recover it.
DaneA
NETGEAR Community Team
- chad2324Nov 28, 2017AspirantIt was a previous employer company email address. So, again not possible.
- DaneANov 29, 2017NETGEAR Employee Retired
Are you the original owner of the NETGEAR device that is registered under your name? If yes, kindly send a screenshot of the serial number that is labeled on your NETGEAR device and the Proof of Purchase (or Sales Invoice) of it via private message.
DaneA
I got your private message. I already inquired your concern to merge your existing accounts and use your current e-mail address that you have used here in the NETGEAR Community. I will post here once I got a feedback.
DaneANETGEAR Community Team
I just got an update. Your existing accounts has been merged and the FS728TPv2 switch is now registered to the e-mail address you are using here in the NETGEAR Community. Kindly check it.
- chad2324Nov 29, 2017AspirantIt works! Thank you so much!
- Dec 04, 2023Retired_Member
