Luis1796
Sep 04, 2018Aspirant
How to back up configuration
Hi, newbie here with first post. I have two GS724Tv4 switches at home which I have set up and are working fine. I want to back up the configuration as I have set up STP to work due to many Sonos comp...
- Sep 04, 2018
Hi Luis,
Smart Control Center show time out maybe the version is not last.
You can download SCC new version try again.
In addition,can download configuration file on switch GUI.
1.Use Smart Control Center discovery the switch IP address.
2.Login switch GUI.
3.Backup configuation file on "Maintenance->Upload->Http file upload",save the "text configuration".
4.Restore congiguration file on "Maintenance->Download".Thanks.
Dan_Z
Sep 04, 2018NETGEAR Expert
Hi Luis,
2.Login switch GUI.
Thanks.
- Luis1796Sep 05, 2018Aspirant
Hi Dan
Thank you for your response and help.
The version of SCC I have is 1.1.3.4 which I believe is the latest version as I downloaded it from the latest GS724Tv4 downloads page.
I followed your intructions to carry the task out from the GUI and it saved a file called 'start-up config' Is that what I should expect to see?
Thanks
Luis
