wgstarks's avatar
wgstarks
How to update firmware from a Mac
I have a GS724T v2 that needs a firmware update (currently V1.0.1_1104) but can't figure out how to apply the update. All the instructions I've been able to find involve a Wizard and I haven't found ...
  • DaneA's avatar
    DaneA
    Jan 01, 2018
    wgstarks,
    Thanks for the feedback.  The GS724Tv2 is an old model of a smart switch and we do not have a GS724Tv2 switch to check it that is why I asked you to look for the menu to perform firmware upgrade.  Since you already navigated the web-GUI of your GS724Tv2 switch and found no option to perform a firmware upgrade via its web-GUI, then I apologize for the inconvenience that you need to use a Windows computer and install the SmartWizard utility in order to upgrade the firmware of the switch.
    DaneA
    NETGEAR Community Team
ProSupport for Business
