wgstarks
Dec 29, 2017Aspirant
How to update firmware from a Mac
I have a GS724T v2 that needs a firmware update (currently V1.0.1_1104) but can't figure out how to apply the update. All the instructions I've been able to find involve a Wizard and I haven't found ...
- Jan 01, 2018
Thanks for the feedback. The GS724Tv2 is an old model of a smart switch and we do not have a GS724Tv2 switch to check it that is why I asked you to look for the menu to perform firmware upgrade. Since you already navigated the web-GUI of your GS724Tv2 switch and found no option to perform a firmware upgrade via its web-GUI, then I apologize for the inconvenience that you need to use a Windows computer and install the SmartWizard utility in order to upgrade the firmware of the switch.
DaneA
NETGEAR Community Team
DaneA
Jan 01, 2018NETGEAR Employee Retired
Hi wgstarks,
Welcome to the community! :)
As per the GS724Tv2 user manual here, the GS724Tv2 switch has a web-GUI that is accessible using a browser. You just need to know the IP address of it. Open a browser like Safari or Chrome. Then at the address bar, type the IP Address your GS724Tv2 switch then press Enter. A window will pop-up asking you for a password. The default password is just the word "password" without the quotation marks. Once you are logged-in, kindly look for the menu to perform firmware upgrade.
DaneA
DaneA
DaneA
