paskaondrej
May 10, 2023Follower
How to upload settings from gs748T V3 ?
Hi We have in our firm an older GS748t V3 and now we buy GS748T V5. Is it possible to save a configuration from V3 and upload (import) it to V5? Is it possible, and if yes than how? Thank y...
michaelkenward
May 10, 2023Guru - Experienced User
paskaondrej wrote:
Hi
That's not one of the Nighthawk Wi-Fi 5 (AC) Routers covered here.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
