hshah96
Dec 19, 2016Aspirant
I am trying to connect my Xbox, TV .. to the switch but it is not working
Hi I am trying to connect my Xbox, TV and WD My Cloud to the internet. I have connected it to the GS108PEv3 switch. When it was connect to the GS116 switch it works but is seems not to be working...
hshah96
Dec 20, 2016Aspirant
Hi DaneA
Thanks for the help.
I am not sure how to start it off. Would you be able to help me out. Either with a Mac or Windows 10 laptop
Thanks
DaneA
Dec 20, 2016NETGEAR Employee Retired
Hi hshah96,
Kindly read pages 14-16 of the ProSAFE Gigabit Web Managed Plus Switches user manual here as your guide.
DaneA
NETGEAR Community Team
- hshah96Dec 20, 2016Aspirant
Thanks, It worked.
I have a Nighthawk Model: EX7000. I wanted to make it into an access point.
There is a connection from the GS108PEv3 to the EX7000 but it is not working. I have connect my laptop to the same connection and I get a connection from it so T am not sure.
Thanks a lot DaneA
- DaneADec 21, 2016NETGEAR Employee Retired
You're welcome! :) I'm glad to know that its now working.
With regard to the EX7000, you may post your concerns on the WiFi Range Extenders & Repeaters Board here. I'm sure the community will be able to help you in setting it up.
Since the GS108PEv3 switch is now working, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Happy Holidays! :)
Cheers,DaneA
