DaveKJ
Apr 15, 2018Aspirant
IPTV VLAN/IGMP Settings
Hello, I would like to ask about the configuration for IPTV network. I use GS748Tv5 as the streamer switch. 16 ports from streamer 1, and 1 port from streamer 2. I've enabled IGMP snooping and cre...
- Apr 17, 2018
Hi DaveKJ,
Welcome to NETGEAR community!:smileyhappy:Did you enable the IGMP snooping on VLAN or interface?
There are different behavior when you set IGMP snooping on these two mode.
You can find more details from following user manual of NETGEAR website.
GS724Tv4 Software user manual Page 108.
May the solution help you:smileyhappy:
DanielZhang
Apr 17, 2018NETGEAR Expert
Hi DaveKJ,
- DaveKJApr 29, 2018Aspirant
Block unknown multicast address solved the issue. Thank you!
