danielator
Nov 08, 2017Aspirant
is there a model like the FS728TP with less ports
Hello, I'm looking for a smaller FS728TP, with up to 8 POE ports. Thanks Daniel
- Nov 08, 2017
Hi Hopchen,
finally, I'll try the GS510TP. It looks suffisant for 4 POE+ ports and with 1GE SFP.
Thanks
BR
Daniel
Hopchen
Nov 08, 2017Prodigy
Hi,
Yes, there are models with less ports that can do PoE and have same feature set. The best option is to look at the Netgear Product Select page. Here you can specify your needs and you can then see what models fit best.
See here:
http://selector.netgear.com/productsearch/FormProductSelector.aspx
Cheers
danielator
Thanks Hopchen,
but, excuse me, it is not practical and not flexible.
(unable to specify "with SFP", like in the FS728TP", ...
Daniel
